- Messages
- 12
- Reactions
- 1
- Points
- 0
The 2022 Bronco Raptor boasts a uniquely upgraded chassis by Ford Performance to provide the backbone for the Raptor HOSS 4.0 suspension and components.
Uniquely designed shock towers are a major part of the upgraded frame to support the FOX™ Live Valve 3.1 dampers.
2022 Ford Bronco Raptor features a reinforced trailer hitch that helps improve towing capacity to 4,500 pounds.
A Ford Performance-designed five-link rear suspension supports an upgraded Dana 50 rear axle and provides 14 inches of rear-wheel travel on the 2022 Bronco Raptor.
Ford Performance-designed A-arms and knuckles enable the 13 inches of front-wheel travel and 37-inch BFGoodrich KO2 tires.
2022 Ford Bronco Raptor features upgraded front axle, steering rack and tie rods, as well as upgraded skid plates.
Ford Performance collaborated with FOX™ to develop the Raptor HOSS 4.0 (High-Performance Off-Road Stability Suspension) system with FOX Live Valve 3.1 dampers. The rear coil-overs with piggyback reservoirs can be seen here.
2022 Bronco Raptor chassis uses four-wheel power disc brakes with four-sensor, four-channel anti-lock braking system and electronic stability control. These upgraded brakes are shared with F-150 Raptor.
Designed by Ford Performance, the Raptor HOSS 4.0 system features an all-new rear design, aside from the track bar.
New A-arms and knuckles enable the 13 inches of front-wheel travel and the 37-inch BFGoodrich KO2 tires. An additional front jounce bumper and upgraded half-shaft are visible here.
